- 2,113
- 563
- 113
- Davis County, UT
Previously I had been aiming to go Michelin XL 11.00R20's in the rear and with Michelin XL 14.5R20 in the front (super single) on A3 wheels. Well, as most things: price, availability, and distance kept getting in the way. This past week end I was blessed to find a couple of deals for G177 11.00R20 tires (a good/decent prices on tires generally hard to find near/in Utah), with a few to spare for my M816. So I jumped in with both feet, and made a whirlwind drive to Star Valley Wyoming, picked up 4 siped tires on deuce wheels and then back to Logan, UT for 14 more tires on 5-ton wheels (I believe they're called bud wheels?).
This was a big "wish list" item for me, and a huge change!
I absolutely recommend Jack's Tire and Oil in Logan, UT in every way. I do not casually trust business working on my vehicles. However, Ryan in the truck shop and his crew are really good folks, professional, and treated me overly well on the bill. They dismounted 18 tires and remounted 9 for my deuce and M105 trailer. The date-code on the tires that I looked at (I did not inspect all date codes) indicate the oldest to be made in early 2000 and newest in late 2007. However, all the tires were "like new" with the nubs and rubber molding flaps. No cracking at all. The folks at Jack's said on regular passenger car tires they will refuse to mount them if they're over 7 years old as the sidewall deteriorates and can split when mounting. I assume they use a different gauge on truck tires. They said the tires look great.
I would still like to do caster adjustment via the methods I've read in a few threads, such as:
http://www.steelsoldiers.com/showth...caster-angle-solved-problems-with-G-177-tires
However, my truck was still very drivable, but on the speedometer (which is now incorrect of course) anything above 45mph feels hairy and the poorer roads demand slower speeds for me to feel comfortable with the handling. I drove home with about 74 PSI in the fronts and 70 PSI in the rears. I think I will lower the fronts to 70, and the rears obviously did not have full tread contact even with the load of old tires and wheels in the back. I will lower the rear tires to at least to 60 PSI, perhaps 50-55 PSI.
I most certainly did notice the slower acceleration from the larger tires. I also had to shift down to 3rd to manage some hills I was just able to do in 4th when on the stock 9.00R20s. However, I still feel the tires are superior in every way! I normally do not operate my truck in the winter here in Utah, but the G177's are Mud & Snow rated tires so I will feel much less... sick? worried?... if I need to. That's a good thing. Though that does not mean that extra caution should not, and will not be exercised!
ANYWAY, pictures, pictures, pictures! I took a number of them.
Loading the majority up at Bridgerland in Logan, UT.
The multi-hour fun at Jack's Tire and Oil in Logan, UT:
