Upgrading HMMWV With More Civilian Components
damarius
charlotte, nc
Please do not discuss titling , off road use etc.. I am aware of forum rules and it should not be discussed here.
Just have a question does upgrading the Humvee to look more civilian affect the resale value.
It would be nice to have some of following
Power Windows
Power Doors
AC
Radio
Trim Around Dash
If it is possible would it be best to convert the existing structure or buy H1 Hummer parts.
DatGuyC
22
Essex, Maryland
Dont forget the HMMWV runs a 24v system, so you are either going to have to convert the truck to 12v or run a separate 12v circuit to power those things.
bikeman
501
Ft. Bragg, NC
AC would be the easiest, as there are mil-upgrade kits for it. Radio... you're going to have to combine that with some sound proofing/doors or similar if you want it like a "normal" car/truck. If you're just looking to blast tunes, look into the Jeep guys and see what happens.
damarius
charlotte, nc
Will any of these proposed upgrades hurt or help the resale value.
One example is the doors. I have considered buying H1 Civilians doors. Of course those are not the x doors.
Does that matter when it comes to resale.
bikeman
501
Ft. Bragg, NC
That's going to depend on the potential buyer.
If I am buying a former military HMMWV, I want it to be military. But the next guy may want the power windows and locks, and radio and such.
Lawdog734
Colbert, GA
I think it does affect the resale value - and not necessarily for the better. Anything you do to it today, I would suggest that you make it easily converted back to original. I liken these to the GPW's and MB's available after WW2. They were plentiful then and not nearly so plentiful now. Those considered more original retain better values than those turned into rock crawlers, etc.
Turning it into a poor-man's H1 doesn't make it an H1, just a bastardized M998 that won't appeal to those looking for an H1 or a clean military truck.
With that said - you bought and paid for it - It's your project to do as you please.
DanM7890
11
Houston, TX
Here's my two cents. I bought my Humvee because it's the ultimate off-road vehicle. I didn't buy it for luxury. As far as resale, any sort of doors will do (hard or soft), a/c is a good, and radio is good but no need to go overboard.
I'm also in Charlotte.
Robus1022
Pensacola florida
4l80e(overdrive), red dot a/c kit, the x-doors have pull out release and springs back in place. Can be done with one hand. 12v Door solonoids($15 each) with 24v transformer($10 on amazon)to intercept the slot behind the latch so the rod will be pinched between the latch for the striker/latch release. A boombox(more or less) strapped down on tunnel (use ammo cans to hold some marine grade woofer. Hook up to 2 channel marine 12v amp with aux in($20 on amazon) and tap into 12v-24v transformer from door lock kits. Use a smart key, or rfid/proxy key to lock the doors and stop the truck from starting. Im sure you could fashion an electric window crank to run the windows, I just personally like the reliability of a manual spring locking window. Maybe attach teeth to the aluminum channel behind the window and use a simple motor with the right size gear. Keep in mind the x-doors are sloppy fit and finish. Windows move around quite a bit. I agree that a military truck should be left original. Also imagine the possibility of losing power and being stuck in the truck...the glass is pretty hard stuff.
saddamsnightmare
80
Abilene, Texas
January 31st, 2016.
I would think that civilianizing an M998 would degrade its value. If I came across such a conversion, the sales price would go down just as much as the parts and labor needed to restore the same to its mil-spec appearance.
However, if you had wanted the best off road vehicle for the buck, I might have suggested an U1300L Unimog, as they routinely outperform the HMMWV off road. This last item is an opinion, but even S404.114 Unimogs will haul HMWWV's out of mud holes, they just won't do it very fast.:shock:
KansasBobcat
San Antonio, TX
The electrical components you mention have all been a source of problems on my H1. The trim around dash just make it harder to work on. I would much rather work on my M998 than on my H1. I agree that value would be lowered because of modifications. Also TMs would be of less help. But it is your truck...
alpha1
Boston,MA
hello, I am loking for any advice or recommendation on upgrading the transmission to a 4 or even 5 speed with Park. any ideas to a matching transmission or how to go about it? thank you.
