airmech3839
- 5
- 18
- Augusta, GA
Deuce being towed will not track with tow truck! Chewing up tires and making life difficult! Any suggestions? Steering not locked up in truck and nothing unusual found! What are possible causes?
If the tow truck driver is flat towing the truck, what's wrong with him?Steering wheel trick seems to be working! I am not with him otherwise I would post pics! thanks for all your info!!
Have him wrap his chains around the springs and lift the front end off the ground and go for the gold.
There is no way that I would flat tow any vehicle more than a couple hundred yards if I could get under it and lift the front or rear end off the ground.
The local transit company on ocassion would flat tow one of their tranist buses into Johnson & Towers to have either the Detroit diesel or Allison transmission repaired under warranty.Because flat towing is a way of life here at steelsoldiers.com.
Now that's funny right there!...if martians vaporized all of our towbars, we would be hopelessly lost!
