use backhoe as a crane?
marchplumber
3,448
Peoria, Illinois
Congrats...............sometimes this old military stuff is tougher than we give credit.
Safety is ALWAYS the key though.
SeeNebraska
24
Nebraska
i think the gantry crane will be useful because i am thinking of building or buying a cnc plasma table in the near future so i'll be buying large sheets of metal that get hard to move from truck to storage to plasma table.
SeeNebraska
What is next?
Forklift, Overhead Gantry
Another Ahab
4,864
Alexandria, VA
Your business, or your hobby? What do you fabricate?
SeeNebraska
24
Nebraska
i guess hobby. i've been around that type of work and used to have access to a full machine shop at work. I switched up my work arrangements, I'm full time remote now and I miss having those tools. so i'm now starting to build up my own shop. the cnc plasma would probably turn into a small side gig though because as far as i know, nobody in my area has one.
SeeNebraska
24
Nebraska
Thanks for the video, now on to some electrical work or are you ready?
electrical for the mill? i need to run a new 220V drop across the shop to a subpanel. From there it will feed a 10hp 1 to 3 phase VFD convertor.
electrical on the SEE? I've got about half the wiring fixed, still something going on with lights, i only have the orange lights working.
Pinsandpitons
66
Central Washington
Thanks for the video. Always nice to watch someone else hop on and off rather than me. One thought that comes to mind ...again, is lifting with the boom locked. The boom cylinders always relief before the stick. Does anybody have thoughts about locking them out with the stowage ring?
biohydrix
Roseville, MN
gorton mill.jpggantry move.jpg So here is my Mill on moving day. I made a Rotary Phase Converter, but I would advise going with the Variable Freq. Drive due to the adjustable rpms. There are two issues that you may have to consider if you have two or more three phase motors on the mill (mine has the main drive motor, a motor for power up/down/left/right, and a third motor for power down on the Quill). First, the VFD doesn't like to work well with multiple motors of different amperage and RPM. You may need to buy several vfd's to make it work. Second , VFD's get exponentially expensive with the higher HP motors. And I added a pic for my lathe as well, since it's prior War vintage.lathe.jpg
biohydrix
Roseville, MN
You can check gsaauctions in your area, occasionally they throw some vfd's and RPC's up there. If you are planning to build a Rotary Phase Converter, find a local electric motor repair place near you and ask them if they have a bin of used capacitors. you can usually get them fairly cheap, like a dollar a piece, as they usually just pull them from a scrap motor, and only come back to the bin if they can't order the replacement.
art
30
Northern N.J.
How about a surplus generator that has 3 phase?
Then you would also have backup electricity for your living area and the backup generator would run regularly.
