rizzo
- 9
- 38
- Port Huron, MI
I've gotten some oil or maybe grease from some places here in town. I don't think it will work cause it is like crisco at room temp. Am I right?
grease or oil?reblawyer said:Meant to say "running some wvo from the local chinese place". Its pretty viscous so I have to heat to at least 120 to filter but its great adding 20% of it to my diesel, cuts down on the heavy exhaust fumes too.
I have my setup almost done, just need to make the time to finish wiring the pump and secure a few fittings. then it's off to get some oil and lye.rizzo said:I found out that the Mexican place is using oil, but they had some grease mixed in because someone ordered the wrong stuff.
I added 5 gal of filtered WVO to my 1008 yesterday and it rand great all day. Started hard this morning. I filled up on diesel and found out that I had a 50 -50 mixture. I think I also had some of the grease mixed in too. I am doing some organizing and get things straightened around so that I only use the oil. I am going to start making bio soon.
lets compare notes. I'm going to start looking for the ingrediants next week after my bog on the 11th. I will PM you with what I found, how much and where.CCATLETT1984 said:I have my setup almost done, just need to make the time to finish wiring the pump and secure a few fittings. then it's off to get some oil and lye.rizzo said:I found out that the Mexican place is using oil, but they had some grease mixed in because someone ordered the wrong stuff.
