using 12v lights in a 24v environment
juanprado
2,829
Metairie/La (N'awlins)
I saw a few posts that reference using two 12v lights in a 24v mv but I do not understand the wiring lay out.
Could someone explain how or post a diagram for "Wiring Dummies" (me) :)
Thanks,
4,695
Wire the lights in series I would assume. Course, then the fun becomes finding out which bulb is burnt out...
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
Only two choices really, but.... according to Mr. Murphy... one will first disassemble the one that is NOT burnt...:)
G.
Heath_h49008
101
Kalamazoo/Mich
The short version, you can take 2 12 volt lights... say some KC Daylighters... and connect them in series. Battery/switch to Positive light#1, negative light #1 to positive light #2, and negative light #2 to ground.
It's easier to just get the right 24V bulbs.
m16ty
211
Dickson,TN
Yea, just wire them in series ( + in to one light, - out to the + of the other light, ground the - on the second light).
This is how I have the pyro and boost gauge lights on my deuce wired. I could have just swapped to 24v bulbs but the gauges came with 12v so I just wired them in series. The only problem is if one light burns out, the other one will go out also.
papakb
1,183
San Jose, Ca
Wiring bulbs in series sounds like a great plan and will work electrically but anyone think about where the bulbs get used? You can't get 2 bulbs into a composite light that I know of and wiring headlights or taillights in series just doesn't make sense. Not when you start running extra wires around to put them in series.
If you want dual voltage lamps get the 10 to 30 volt LED lamps that are on the market today and be done with worrying about what you have in the system
Kurt
1,172
It gets complicated to wire in series when the 12v light fixture is grounded by it's mounting hardware.
