Using 4 man curtian with rear cargo cover?
tkdtim
Green Bay, WI
Whats the proper method to use the 4 man curtain with the cargo cover? I was thinking maybe mount the curtain on the outside of the soft top and only attach the top so it can roll up? Is the curtain normally used when using the cargo cover?
DatGuyC
20
Essex, Maryland
I attached mine under the top because putting it on the outside would let rain in, just have to undo the sides if I want to unroll it and attach it there.
tkdtim
Green Bay, WI
I got it all together, thanks guys! Top was a bear to stretch on, probably because its almost 30 years old and dry. Tight like a drum in most places. There is a 2'x2' section on the top that is sagging a good 4-6" like snow sat there or something. Wondering if I can heat weld a new piece of vinyl over this area, then cut out the sagging portion...I'll leave it for now since it doesn't move when driving.
