Using a 5-ton to haul hay
allgonoshow
Longvalley/SD
I am thinking about buying a 5-ton 6x6 to haul 6ftx6ft round hay bales. The sales guy that I talked to says that it has a box on it. He has no info on it at all because they just got it in and the mechanics are going over it before they put it up for sale. I guess what I am wondering is what size boxes come on the various 5-tons. Would this make a good candidate to haul hay with? Any advice as to what to look for? Thanks for any help!
EMD567
Driver for the Ga Mafia
47
Aiken SC
You have four choices. THe M813/923 with a 14x7' bed, and the M814/927 with a 20x7 bed. The 800 series have the deuce cab, 5 speed manual trannys, and single circuit air over hydo brakes. The 900 series have auto trannys, air brakes, and slightly larger cab.
trooper632
Utopia, TX
I have a setup like pctrans, But i was limited to 15 bales due to the size of the trailer, The performance of the truck just plain sucks on the highway, transported bales one time about 40 miles, wont do it again with the 18, but coming out of the field would be fine.
jimmcld
Denton, Texas
The beds are really not big enough to make it a good hay truck. However, before you buy it, make sure that it at least has a "drop side" box. If not, you won't be able to use it at all.
allgonoshow
Longvalley/SD
This looks like it works ok? It does not appear to have a "drop side" box. However I'm sure the drop side would work much better as you stated.
gunboy1656
22
Beaver Falls, PA
If your doing round bales it would not make a difference which truck you use, since the center of the bale is high enough for the spike to go it. Now if your doing square bale, then yeah get a drop side.
That would not be fun trying to offload all those bales by hand.
jimmcld
Denton, Texas
It looks like he must have put something in the bed to stack the bails on above the sides of the bed, and I guess if you were only going to haul them "one wide" it would be OK.
