- 8,698
- 3,204
- 113
- Monrovia, Ca.
I came across a 5T USMC truck in the back 40 of the museum on Sunday. It is the first and only truck I have seen intact clips on. Still need measurements? I can get them tomorrow. Pics too, if you like.
Why have those when you have the lifting shackles?
I was in the Corps in the early 1980's and we still used them just for the reason I stated earlier. All the deuces that I ever saw had them, but then again I was in "landing support" so we where the ones off loading at the beach head with combat loads.OK, OK, I know this is an old thread, but for anyone wandering the halls of the thread this:
THe paper clip brackets were used for a couple of reasons. THe safety factor was one component. If it fit it went was the criterion. The second was ease of loading and unloading.
THe vehicles were usually swung using a four cable bridle or sometimes a chain bridle with open throat hooks which took more time to fit into and out of the inboard lifting shackles. Additionally moving the lifting points out made for a more stable lift. Case in point: THe Mighty Mites, which were designed to be air lifted had outboard lifting brackets.
In '65 the M37 we used for towing the water buffalo had them. After the truckmaster snagged himself a second time on one that was bent outward, a private was summoned, given a dull hacksaw and instructions to cut the *********** things off. "Torch,Torch, we don't need no stinkin' torch. We got privates, PFCs and hack saws. Maybe even one with a new blade."
They weren't very common. I don't remember seeing a lot of 35s and 54s with them. IIRC 7th Heavy Junk was at DaNang and their wrecker had them.
The brackets were handy for stowing a tow chain and hooking to when the vehicle got buried. You could get a grab hook through the opening easily, especially if the front end were buried, but they bent easily so you had to pick your spot. (see above) It was best to wrap the chain or cable through the loop and around the bumper. Similarly you could easily pass a chain through both and get a nice straight pull. No screwing around fitting a chain through the inboard brackets. Of course a winch made things even easier as long as the shear pin hadn't broken and not reported or changed, the PTO shaft was straight, still in place and the shift fork hadn't been broken by applying a two pound speed wrench to the handle. Was a time, Was a time.
