V Belt for larger PS pulley groove?
erasedhammer
56
Maryland
Did the 12v conversion and deleted the driver's side alternator and now I'm trying to find a v belt that fits the larger groove on the PS pulley.
Anyone know the circumference difference between the inner and outer grooves on the power steering pulley?
I do not have a way to measure it.
porkysplace
1,486
mid- michigan
You don't have any rope ?
ridenby
Frankfort,Ky
Could you share belt size you used? Please.
erasedhammer
56
Maryland
Belt for the larger groove pulley is a Gates XL 7475 11A1205.
I would be hesitant about that exact belt. It is just a little bit too long. When the PS pump is tensioned, it is still a bit loose compared to the inner belt.
Haven't had any squeaks when turning though.
Id say if you could find a belt 5mm shorter, it might tension up better.
