ccf460
- 1
- 18
- granite falls/N.C.
I have had my vaccum solenoid/valve on the IP bypassed for so long that I can't
remember where the lines go? The valve has 2 nipples, upper and lower. Which one
is fed by the vacuum pump, and which one feeds the transmission? If someone could
take a quick peek at theirs, I would appreciate it. Also, what seems to be the average
starting position on the side of the IP, mostly forward/back/middle. I put the new
valve on with no change, I want to make sure the top end is right before I go after
the modulator.
the modulator.
