Vacuum Regulator Valve Fitting?
The TH400 in my M1009 took a crap, I plan on putting a Nv4500 in its place but due to a lack of funds and me needing my truck I'm attempting to get it fixed. So far I’ve only replaced filter and fluid, vacuum tested the modulator valve and found this little rubber fitting on the vacuum regulator valve to be dry rotted to a point where wiggling it would cause me to loose vacuum psi quickly. what is this part called or a part number so i can replace it or do I really even need it? Can I just put the hoses on the valve and call it a day? Thanks.
Warthog
227
OKC, OK
You must have the European version of the injector pump. Everything is on the wrong side. ;-)
Like cpf said the fitting is no longer available. Just hook the hoses directly to the valve. The top fitting is for the line going to the transmission. The bottom fitting goes to the vacuum pump.
