Due to some excessive oil leaking around the top of the oil fill pipe, I'm swapping the CDR valve and vented oil fill cap. (found both cheap, and need a quarantine project lol)
While poking around on my "ever increasing quest" to swap rotten rubber lines (34 years in the Texas heat seems to be their limit), I noticed the vacuum lines on my vacuum regulator valve are pretty badly rotten / cracked.
Is it worth swapping the vaccum regulator while i'm here? AC Delco parts are going pretty cheap on ebay atm:
(link removed by author. AC Delco 14057219 $29 USD)
I've had some weird shifting issues in the past (random hard shifts, delayed shifting)... so thinking this could be related?
![IMG_20200321_172446.jpg IMG_20200321_172446.jpg](https://www.steelsoldiers.com/data/attachments/548/548564-df75bf5602cab8f4ae24b7b71b3bc93b.jpg)
Thinking of pulling the intake manifold and replacing the low-pressure fuel lines too (they're rock hard)
