valve adustment signs and symptoms
russ132
Kelleys Island OH
Hi all,
I was hoping to find out how the need for a valve adjustment would show itself. What symptoms would my deuce show? Thank you all for any information.
WillWagner
2,532
Monrovia, Ca.
Sounds like a smith corona typewriter, If they are out of adjustment too bad, it can smoke lots, not be so smooth at idle, just sounds kinda ratty. After a correct adjustment, you'll notice better power, better mileage...like THAT matters :roll:, better throttle response and it'll just sound better.
Westex
El Paso, TX
I've been curious about this also; where do you get a fresh gasket for the cover(s)? Or do you just make 'em up with RTV gasket maker.
russ132
Kelleys Island OH
Thank you all for the info. I have been having a little more drool out of the slobber tube but other than that I haven't had any problems. Still runs great. More than anything I am just curious if I should adjust the valves or not. Probly would not hurt. I can hear the valves rattling around but I am unsure if it is excessive or just the norm. Thanks again.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
If you have not ever done them I certainly would. Your gonna need a helper to get the timing lined up, but not too hard of a job. The timing info is in the LDS troubleshooting manual.
Srjeeper
40
NE, Pa.
The reason for a bit more slober could be due to lower air temps, so I wouldn't worry about that too much.
There's plenty of posts on here about doing the adjustment...or simply follow the proceedure in the TM and you'll have it done in no time. I do mine about every two years and there's very little if any change between adjustments. As a rule it only takes about 1/2 hr. 45 min. and you always do them cold.
When you put the new gaskets on, smear them up with Diaelectric grease and they'll never stick, you'll be able to reuse them for years to come as long as you don't crush em.
