Inspector 1
- 73
- 28
- Spring Texas
I confirmed that my transmission fluid was entering the Transfer Case. When I removed the Transfer Case fill plug you can see from the picture all the transmission fluid that came out. I ended up disconnecting the transmission lines from the transfer case and looped the two lines together. I capped the two transfer case lines. I also replaced the rear Gear Hub vent line. Problem solved. Here are some pics of the job start to finish.
