Veggie/diesel mix
wreckerman893
Possum Connoisseur
15,645
2,130
Sorry if this has been discussed before and I missed it but I just got a good buy on an 87 Ford Ranger diesel.
The owner said he had been running veggie/diesel mixture.
Anybody else do this?
What is a good mixture?
I'm in AL so low temp is not a problem right now.
Thanks for any help.
5tonpuller
29
Thompson, Pa
Thats what I been using in the my wrecker. I mix it 1/2. The pump still needs that slip that oil gives it. I know the $ for the pump stuff is high, but what the price of inj. pump and injectors.
If you need more PM me.
Matt :)
ygmir
northern CA
RE: Re: Veggie/diesel mix
I've heard there may be longer term issues with mixing diesel and WVO or SVO and precipitating waxes from solution........
I've not done it, thoug, so can't speak directly.
Please keep us informed.
jefe066
Liberty Hill, Texas
From what I understand, the veggie oil will slip past the rings until engine at operating temp. The veg. oil will then polymerize in the bottom end. Changing the lube oil sooner, maybe half miles, you can avoid too many problems. At least after filtering the wmo you could use it as fuel.
cranetruck
92
Meadows of Dan, Virginia
The proportions of veggie oil to diesel will depend on how you are using your truck IMHO.
If you are on a long trip and run the fuel down (in the tank) constantly, use a higher percentage of VO, perhaps 80%, it is kept warm by the return flow.
If you use the truck in a stop and start, now and then, use a lower percentage, perhaps 20% VO or you'll have trouble starting the engine in the morning even if the temp doesn't drop below 60°F.
I'm talking from multifuel engine experience, the Ford Ranger may not be as coopertive.
wreckerman893
Possum Connoisseur
15,645
2,130
Four weeks of running 1/2 veggie and 1/2 kerosene (4 bucks a gallon) and the Ranger is running great. No problems starting so far.
I am going to build my heat exchanger and switching system as soon as I can so I can cut down my overhead.
If I can get more clean oil I will be converting a deuce or 5 ton to veggie soon.
superburban
SL,UT
wreckerman893 said:
Four weeks of running 1/2 veggie and 1/2 kerosene (4 bucks a gallon)...
Where do you buy your kerosene? Here in Utah, kerosene is used mainly as a portable space heater fuel and is sold for around 8$ a gallon.
wreckerman893
Possum Connoisseur
15,645
2,130
I get it at a convience store enroute to my job.
There was another place selling it for 3.50 a gallon but they are habitually out (maybe someone else discovered the secret).
My price for fuel is about 2.25 a gallon if you count my time and effort to strain the veggie.
