VIN Info-'You may fire when ready, Gridley.'
MWMULES
351
DESOTO, KANSAS
Re: M109A3 SHOP VAN VIN PLATE
the fog is really thick now!! since my replacement data plate was done with engraver I scraped the paint of the left frame rail and have now found the following set of numbers
22 2793L
3 6 67
1072204
WHAT DO THESE 3 LINES MEAN? Thank you again in advance. Dave C
CARNAC said:
MWMULES said:
Oh great sage please burn off the fog that clouds my veiw.
Picked up my M109A3 shop van at Ft Riley yesterday, from auction in early Sept
nsn2320-00-077-1636
ID 0230-10304 4L467 which is reg# on door& under hood
contract DAA06-70-c-0001
From contract was it made in 1970? Who made it?
Thanks in advance for the help. Dave C
Organization: 3657TH OD CO GEN SPT MAINT
Nomenclature:TRUCK VAN SHOP Model:M109A3 NSN:2320000771636
Serial Number:23010304 Registration Number:4L4591 Year of Mfg:1967
Nov82 info
No info on mfg but David Doyle (DDoyle) should be able to tell you based on this info.
CARNAC
The Envelope Please.
712
College Station, TX
Re: RE: Re: VIN Info-
Engine5 said:
Oh great guru of green,
What can you tell me about this. 1971 deuce Kaiser m35a2
VIN # 04p-61371 04596
I think it came out o fPA or NJ, not sure. Would appreciate any info.
Thanks , Mike
Organization: 1043RD OD CO MAINT NONDIV DS
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A2 W/W NSN:2320000771617
Serial Number:53914596 Registration Number:4P61371 Year of Mfg:1971
Usage Miles: 43001
Sep 04
Was with this unit prior to Sep04
1st BN, 206 FA, HHS 105MM SIB RUSSELLVILLE, ARKANSAS
CARNAC
712
College Station, TX
SgtHatred said:
VIN: 126779
NSN: 2320000771616
Type of vehicle: M35A2
Where you bought it: GL, Mechanicsburg, PA
Month/Year you bought it: 09/2008
Additional info from invoice: W25KKN80130502A
I don't have the truck yet to verify numbers and only have my invoice to go by. I need the Year/Make to get insurance to pick it up and get temp tags.
Thanks for giving us such a great service. You are appreciated. :)
The information provided is not correct.
CARNAC
712
College Station, TX
319 said:
Mr. Carnac,
Okay, my turn.
Picked up an M1009 from Columbus Monday.
1984
Vin: 1G8ED18J9EF153472
Registration (?) number on doors and hood: NF03UG
Shows 5749 miles (probably can add 100K to that)
(Donation to follow)
Thanks!
No info.
CARNAC
712
College Station, TX
22 2793L
3 6 67
1072204
nsn2320-00-077-1636
Nov82 info
Not sure but they are not bringing up anything in the database. Someone said one of these numbers is the frame manufacturer cage code.
gmayor
St. Robert, MO
RE: Re: M109A3 SHOP VAN VIN PLATE
I guess I want to find out the background on my fire truck. It is an M45 NK03WY with 0534-10572, bought it in April or May 2004 from GSA in Lebanon, MO was painted red so fire department used it for some time.Thanks been wanting to try this.
MWMULES
351
DESOTO, KANSAS
CARNAC said:
22 2793L
3 6 67
1072204
nsn2320-00-077-1636
Nov82 info
YEP, my 1967 109A3 Kaiser and another 67 M109A3 bought at auction both had this nice set of #'s stamped on the frame just in front of the drivers side shock mount. That is what has lead to my confusion to location. I have since looked father foward and found just aft of the steering linkage the following set of #'s 0230 10364 so whoever made up my replacement data tag made a zero instead of a 6. What should the registration # be? Thanks again for all your help. Dave C
wsucougarx
Washington State
CARNAC said:
wsucougarx said:
All knowing one, please help me out w/some trailers I won at FT Lewis 9/08.
The first one is a M105A2 made by Spade Leasing. Not sure what the year is.
a. Serial Number: NW0EVESL0042 -or- NWOEVESL0042 (dont know if thats a Zero or an O after NW..)
c. Vehicle NSN: 2330001418050
d. Type of vehicle: M105A2
e. Where you bought it:FT LEWIS, WA
f. Month/Year you bought it: 9/08
The second is unknown manuf and unknown date of manuf.
a. VIN also known as serial number (SN): PKO30WADC0893
b. Registration Number (Reg#)
c. Vehicle NSN: 2330002001785
d. Type of vehicle: M332 1.5 ton ammo trailer
e. Where you bought it: FT Lewis, WA
Nomenclature:TRLR CARGO (1-1/2T) Model:M105A2 NSN:2330001418050
Serial Number:SL0041 Registration Number:NW0EVE Year of Mfg:1987
Manufacturer:9X384 Contract Number:DAAE0785CJ078
It is always a 0 (zero) and not an O (oscar), just like it's always a 1 (one) and not an I (india).
No info on the second one.
Oops Please try this one:
a. VIN also known as serial number (SN): PK0 30W ADC 0893
CARNAC
712
College Station, TX
Still a no go. The database doesn't use spaces or dashes. All numbers are run together anyway.
CARNAC
712
College Station, TX
Re: RE: Re: M109A3 SHOP VAN VIN PLATE
Organization: CO C 35TH ENGR BN
Nomenclature:TRUCK FF Model:750 NSN:4210001067432
Serial Number:FT750022 Registration Number:NK03WY Year of Mfg:1972
Manufacturer:90598
Mar 91
David Doyle might know something that I don't on this. What I suspect is the military was tracking the vehicle under the 'system' (as in fire fighting equipment) VIN. The correct on for registration purposes should be the frame serial number. That is the one police officers will look at.
CARNAC
712
College Station, TX
MWMULES said:
CARNAC said:
22 2793L
3 6 67
1072204
nsn2320-00-077-1636
Nov82 info
Organization: GS MAINT SITE KS ARNG
Serial Number:23010364 Registration Number:4L4676 Year of Mfg:1984
Usage Miles: 383
Info Sep 06
At this time it was suppose to go to Company B, 132 SPT BN in MAUSTON, WISCONSIN
Not sure if it made it there though.
MWMULES
351
DESOTO, KANSAS
BINGO! You called it the bumper #'s on truck are 32BDE 132FSB B117, the Reg is#4L4676. The frame is a 1967 but found out it went through rebuild in 84 hence the redone data plate. Weird thing is the motor has a contract # of DAAEO7-87-C-JO69 . The GL site and the A3 duce rebuild are just down the road at Ft Riley from the KS maint site. It had 400 on the speedo before I drove it home last week. Thanks again for the wisdom. Dave C
CARNAC
712
College Station, TX
StreetbikeDepot said:
another M35A2C....
2320 926 0873
NKO370 0540 10261
DAAE 06-70-c-001
Thanks!
Organization: 995TH MAINTENANCE CO
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A2C NSN:2320009260873
Serial Number:54010261 Registration Number:NK0370 Year of Mfg:1972
Manufacturer:65909 Usage Miles: 13859
Info SEP04
gmayor
St. Robert, MO
RE: Re: RE: Re: M109A3 SHOP VAN VIN PLATE
Thanks, on the fire truck. The GSA listed the serial numberas FT750022 and thats what Missouri titled it as. I took the data plate numbers to give to you. You definitely found the right truck. Great!. Thanks.
moose53
Bordentown NJ
oh great Carnac...
2320-177-9258
02LJ3471-39475
DAAE 06-68-C-001
DOD-2/71
I hope you might be able to tell me something about this one....
Jim
ragedracer
Phoenix, AZ
1G8ED18J1GF153517
NFOJ5C (the O may be a 0)
c. Vehicle NSN (VERY IMPORTANT FOR ANYTHING OTHER THAN DEUCES)
2320-01-123-2665
d. Type of vehicle
M1009, Model CD-10516
Barstow, CA
August, 2008
Has #s painted on doors that read "SD 3517"
Thanks!
CARNAC
712
College Station, TX
moose53 said:
oh great Carnac...
2320-177-9258
02LJ3471-39475
DAAE 06-68-C-001
DOD-2/71
Jim
Organization: 416TH CIVIL AFFAIRS BATTALION
Nomenclature:TRK UTIL 1/4T W/ROPS Model:M151A2 NSN:2320012644819
Serial Number:39475 Registration Number:2LJ3471 Year of Mfg:1971
Usage Miles: 10491
Info Jun 88
CARNAC
712
College Station, TX
1G8ED18J1GF153517
2320-01-123-2665
d. Type of vehicle
Barstow, CA
August, 2008
Thanks!
Organization: 540TH MAINTENANCE BN HHD
Nomenclature:TRUCK UTILITY 3/4TON Model:M1009 NSN:2320011232665
Serial Number:J1GF153517 Registration Number:NF0J5C Year of Mfg:1986
Manufacturer:93219 Contract Number:DAAE07-82-C-4060 Usage Miles: 53470
Info Sep04
As for serial numbers and registrations numbers, it's always a 0 (zero) not an O (oscar) and it's always a 1 (one) and not an I (india).
