Vinyl cargo cover repair - loops
Kharville
Clinton LA
In searching the forums I don't see much in the way of an answer on repairing the tie-downs on the vinyl cargo cover when they come unglued. These are the pieces the super rope passes through. Some have mentioned glue/cement and "plastic welding". Has anyone actually repaired one of the "loops" that the rope passes through on the vinyl cover for a Deuce? Photo below of the item I am addressing. The one in the picture is intact. I have one that came unglued from the cover on one side.
juanprado
2,756
Metairie/La (N'awlins)
I used contact cement to do just what you are trying to do on a vinyl 5 ton cover.
I also added a rivet on each corner to gve it strength and used a black sharpie to tone them down.
SCSG-G4
PSVB 3003
3,221
Lexington, South Carolina
I've repaired some with Shoe Goo after thoroughly cleaning the surfaces and making a large enough clamp by using some boards to keep everything flat for 24 hours. Getting the surfaces clean is the key.
