Re: RE: Visually telling the year.
FreightTrain said:
Nope,From 1954 or whenever the first was built to 1988 or whenever the last was built they are identical externally.Only major difference was teh headlights on the early ones were low but that was so easy to change and sometimes newer trucks got changed to low headlights when body work was done.
Regarding the A2s I agree there are no changes, except may be different mirror styles.
But NOT since the early fifties when the first M35s came out! Basically the same dimensions yes, but there are many (minor) visible differences between gasser and MF version, like higher grille, different engine side panels, headlamp brackets, dash panel, cab floor tunnel, etc.
Yes, the early rubber mounted HL supports are easy to flip upside down, as well as the short segments of the grille, left to right. If it was a winch truck it came with the headlamps mounted high, otherwise low.
G.
