Volt gauge
Warthog
244
OKC, OK
There are two fuses and a relay that control the voltmeter.
First fuse is the 24v fuses that feeds the voltmeter and is controlled by the relay. Second is the 12v ignition fuse. When the key is on it feeds 12v for the relay to energize and send the 24v to the meter.
The voltmeter relay is under the center dash. It is next to the starter and GEN2 relays.
Also the 300 ohm resistor on the voltmeter has to be in working condition.
Warthog
244
OKC, OK
Fuse #12 and #15 in the fusebox.
you can find the fusebox diagram in the TMs, the CUCV FAQ thread or the CUCV Fusebox Layout thread that is listed in the CUCV Helpful Threads sticky.
Also the TM 9-2320-289-20 tech manual has a step by step troubleshooting section for a non-working voltmeter.
Warthog
244
OKC, OK
The voltmeter resistor is 300 ohm. Many threads that discuss it.
