Voltmeter question???
SGTskully
Gothenburg, ne
My voltmeter stopped working lately and come to determine that the ceramic resistor on the back is bad. I cant find one listed ar in a tm anywhere. Does anyone know the value of this item as I caould find an equivalent somewhere and just replace it.
Warthog
224
OKC, OK
If it part of the voltmeter, then replace the voltmeter itself.
Just my $0.02 cents...
CJ, the resistor is external from the VM. No need to replace the VM unless it's bad. Just my .03 cents. Inflation you know.
cpf240
Free in Northern Idaho
Combining resistors? 300 ohms is a common value. It should be readily available. What's the wattage rating?
I believe it was done to create something to handle the load. Also, keep in mind that this is just what I remembered off the top of my head, I have not re-read the thread(s) in question. I'm not sure Rat Shack carries the heavier-duty power resistors anymore, or at least not in their brick-and-mortars.
367
Castalian Springs, TN
Super Duper easy fix.... either get a 300Ohm reisistor or link 2 150 ohms... Search.... Search my friend... you will find the answer you seek.... I had to do the same mod about 8-9 months ago... Been working perfect ever since....
MarcusOReallyus
811
Virginia
Don't just go out and buy a couple of 150s and think you are done. You need to know the wattage rating. If the original is a 1 watt resistor, you need 1/2 watt 150s in series. If you use a couple of .10 watt 150s in series, they are going to go up in smoke.
Oh, and don't put them in parallel. That will give you 75 Ohms. Smoke!
SGTskully
Gothenburg, ne
Thanks All just needed the value its not marked on anything. I have a degree in electronics so the repair is no biggie just didnt have a value.
combatmech
Carrollton, Texas
That's how I fixed mine..... Has been working for three years now, no issues.
MarcusOReallyus
811
Virginia
There's a wide gap between "getting lucky" and "doing it right".
Sometimes you get lucky. Doesn't mean you did it right. You happened to get a couple of 150s that were the right wattage for the job (so far). So the next guy who takes your route might not, because he doesn't know any better.
combatmech
Carrollton, Texas
This is very true. I am no electrician by any means. Upon further review of my information and looking through my pre-x bin, I used one 330 ohm, 1/2 watt 5% tolerance resistor. ********* My apologies Marcus. *************
Nacademus
Sheffield Lake, Ohio
That half-watt is too low, and your resistance is too high. I found, with my volt gauge, that at almost exactly 300 ohms (3x100 ohm in series), 1 watt a piece- I measured exactly HALF of what I was getting from the high alternator.
You could also put in a pot instead of the resistors and adjust it down to wherever you calibrate is half the total value.
