American Patriot 1960
- 41
- 18
I have been kicking an idea around for some time now and I thought I would ask for some input.
I have a need for a off road capable trailer to haul a Jeep size vehicle, a quad (4 wheeler) a dual sport motorcycle and 100 gallons of gas, 100 gallons of diesel, 100-200 gallons of water and a grey water holding tank of for 100 gallons. All of this weighs 900-1,000 pounds. EDITED TO CORRECT: 9,000 to 10,000 pounds.. Sorry about the typo/brainfade!!
After lengthy consideration I feel that a "Wagon trailer" design is likely to be the best option for stability, especially off road. I'm not talking about class 5 off road trails (Obviously!) but this unit will see plenty of off pavement use on less than improved roads. Likely some creeks and so forth.
I have reviewed the M989A1 and the M1076 PLS trailer ( PLS M1076 Trailer : Oshkosh Defense ). The 989 weighs in at just over 10,000 pounds and the 1076 is something around 16,500 or so.
One thing I have not been able to learn from the manuals is the length of the 989 from front to back if you go from the front of the front deck to the back of the back deck. I know several SS members have these trailers, perhaps somebody could measure that for me?
Of the two I think the 989 would work better. I had looked at the 1076 hoping it weighed less than the 989 but with the 3rd axle it is over 50% more! I suppose I could take off the center axle but I'm pretty sure that even after removing it and modifying the rear suspension as needed it would still weigh more than the 989.
I have seen a lot of guys take a M109 truck and remove the cab and front axle to make a trailer out of the back 1/2 of the truck. This got me to thinking about taking a beat up Deuce and pulling the body, bed, engine, trans, transfer case and center axle. This would leave me with a frame, front axle and rear axle. Obviously the rear suspension (Springs) would need some attention after removing the center axle, possibly use a set of front springs from a scrapped truck?
Doing this I would remove the differential and axles from the front axle housing and possibly from the back. I would have to make the towing/steering mechanism for the front end of course. Build a flat bed deck and go from there.
So, this gives rise to some questions that I can not answer and some ideas that I would like/appreciate feedback on.
First is weight. What would a front and rear axle assembly, springs and frame weight (With the axles and diff out of the front)?
I am thinking of leaving the rear axle intact and making a mount for a hydraulic motor to attach to the input where the drive shaft normally goes. Build a hydraulic pump/motor assembly similar to what they use for the "Jaws of life" and mount it on the trailer. this could be used to maneuver the trailer when it was detached from the towing vehicle. If the tongue was to difficult to push side to side for steering a hydraulic ram could be installed there as well and I could actually "ride" the trailer during re-positioning. I know it will not be fast. I don't want or need it to be. I just want it to be able to move on it's own to make hooking up easier. Also, I know that the wagon style trailer is near impossible to back up so this would give me some insurance should I (Stupidly) find that I have gone into some place that I am forced to reverse out of. Is this concept even feasible or would the pump and or motor required for this be completely impractical?
Next is the towing/steering mechanism, lets call it the "Tow bar" for now. On the 989 the tow bar appears to be attached to a vertical assembly looking like a pipe that is installed in a set of heavy duty bearings to allow the pipe to move side to side (More like pivot, left and right) with the movement of the tow bar. The tow bar is also allowed to move up and down at this attachment point. The tow bar extends rearward passed the pipe and the drag link that does the actual steering is attached to that and down to the front spindles on a bracket (Steering arm?) that instead of extending to the front like on a normal vehicle extends to the rear to allow for the tow bar to easily direct the front wheels. In order to get the steering arm to point to the rear rather than the front could the axle simply be rotated 180 so that the plate covering the hole where the differential was is now facing down? (Added benefit of a bit more ground clearance) Would that work or would it screw up the ability to provide a proper alignment of the front end?
Coming up with the mounting and design of the tow bar attachment to the "Pipe" and the brackets, bearings and such should not be to hard to design after some discussion with a mechanical engineer to be sure that proper size materials are used.
The "Stripped truck" idea is intended to do 2 things that the two previously mentioned wagon trailers don't/can't. One is to provide a lighter base unit for the project so that the finished assembly is lighter. The other is to provide for "Self mobility" should the need arise. If either or neither goal is reasonable/possible then I'll probably just look at the 989 some more.
This leads to a couple additional questions on the 989 for those of you that have one to actually look at. I believe that the drop sides provide no structural support at all and could just as well be removed (From a structural integrity point of view). Is this correct?
Next, on the front there is a fire extinguisher mounted on a "Lip" that extends up above the flat deck. There is a similar lip on the back deck. Without sacrificing any structural integrity could those two lips be cut down to be flush with the deck?
Are there any other already built wagon type trailers that I should look at?
I think that pretty much covers it for now.
What do you guys think?
