fal_shooter
- 0
- 0
- Post Falls, ID
I looked at all the postings and I saw the routing listed two different ways. I would like to confirm the routing just to make sure I have it right.
I will be using Gatorback belts so I will list their part numbers as part of the confirmation.
Back belt #15461
Crank/water pump/ PS pump
Center belt #15581
water pump/drivers alt/crank/PS pump
Front belt #15485
water/crank/pass alt
I guess what I am confuse about is do both the center and back belts go to the PS pump? I saw it listed that way on one of the several postings I saw here but that could be an error.
I appreciate you help on confirming this. The guy that was working on the truck took all the belts off then told me I got the wrong size.
Back belt #15461
Center belt #15581
Front belt #15485
