74M35A2
- 342
- 83
- Livonia, MI
Maybe that is what I should do instead of replacing my broken back window glass...
PLease do.Maybe that is what I should do instead of replacing my broken back window glass...
Guy said cooling is 36,000btu and 48,000btu heat. Should be good for up north.Maybe that is what I should do instead of replacing my broken back window glass...
Most cars wont blow below 55 or so. Optimum pressures should be 170/30. dropping to 18 at 2,000rpms. At 10 it could start to freeze up. . The evaporator is 42 degrees at its core and the expansion valve is at 52. The pressures also indicate that the system is undercharged so it could get colder. But. 30 to 45 degree difference between outside and inside is Alot in the southern heatI'm impressed with your work. Your homemade brackets look like they turned out well. However, do you consider 50 degrees ice cold air? That system should easily get lower than that depending on ambient air temperature. If you're running R134A, those head pressures seem way low. I see it's 88 in Memphis today so your delta is 38. Is that what your AC person said was ok? I've built systems (using similar components) that will blow lower than 40 at 90 ambient. So when it's 100 there, your vent will be somewhere around 60 moving and 70 idling? Is that ok with you?
I'm just about to start mounting my AC bits on my M923. I'm using the kit for the M916A2 or A3 (I can't remember which) and it doesn't have fans on the condenser. I'll report back to see if I get it to blow colder.
Enjoy the cooler air!
Al Jones
M923
Brookings, SD
I had the pressures backwards when i typed it. Dyslexia kicked in. I was parked in the shade when i charged it as wellHigh side of R-134a should be 2.2-2.5 times ambient temp. Duct outlet should be near 39F. Low side 25-40psi.
Compressor wont come on unless the fans are on. I will mess with it tomorrow.Yep, chart will work. Condenser have fan running?
Wes,Compressor wont come on unless the fans are on. I will mess with it tomorrow.
There is no point for the compressor to be on all the time especially if the system isnt on. Your compressor has to run thru the pressure switch somehow. Mine just jumps a power wire to engage the single wire compressor rather than having to run another inline fuse to protect it. The fans and the relay are wired into the pressure switch on the dryer. . Fans go off. Compressor goes off. My system is overkill for the cab but general complaint in the summer time is that the red dot units have a hard time keeping the cab cool on a solid steel cab. Mine on low at 95 outside will give you chills. It doesn't have to work hard at all.Wes,
two things for you.
I dont know your setup. So I'll use mine as an example. The Red Dot units made for hummers keep the compressor on all the time. Yeah, sounded odd to me too, but after a year, it's ice cold. Still works.
The pressure ports on the evap/dryer dictate at what pressure the fans kick in and when they turn off. I don't remember what the pressures are though. Yours may or may not have pressure ports there. Do they have pressure ports anywhere? Or are fans run on temperature of coolant?
I left My gauges hooked up for a day while i drove around. Give it a shot if it's mechanically possible. I drove dallas to Texarcana with mine hooked up. See the pressures in the morning and in mid day heat. Then you will have a good idea.
oddly enough, while driving, it took the fans longer to cool the condensor. There must be natural opposite airflow coming from the top down. I should consider if it's possible to reverse my fan direction.
I am fairly certain that is what the Red Dot Hummer system does. While I do not remember the numbers, it comes on at exactly 400, for example and off at 250, again, for example. Every time. No difference in any other variables. Rpm, outside temp, etc.Advanced systems use a pressure sensor to run the condenser fans on an as-needed basis, completely separate of the compressor clutch signal.
