Warning lights
Elk1111
493
Las Cruces NM
I have no warning lights for low air, parking brake or transfer case. My spring brake light and bright indicator work fine but my low air buzzer is also very faint.
I filed down the grounds but still nothing and the main problem I am having is the numbers on the wiring are corroded and very hard to read. Where is the best place to start troubleshooting this?
simp5782
Feo, Fuerte y Formal
9,498
Mason, TN
Assuming the bulbs are in good working order. Pull the panel and Use a meter on the wires behind it. How much power do you have at the socket when the light should be on is the first step.
Elk1111
493
Las Cruces NM
I traced the warning lights not working to one of the wires coming off the starter switch. If I move it around the warning lights start working and the buzzer gets loud but if I move it too much it kills the truck??? Now the lights work but sometimes the truck just clicks in the PCB when I try to start it. I’m thinking I need to replace the wire from starter switch to the PCB and hopefully I don’t have to replace the PCB box.
