mudguppy
- 15
- 0
- duncan, sc
this is both very confusing and mostly incorrect. the only correct concept in this post is that the waste gate limits the turbo output. however, that is not the reason for a waste gate.a waste gate is there only to limit max boost .the reason the waste gate turbo it better is because it flows more on the compressor side and the exhuast side . so it can make more boost at lower speeds without overfueling. it can take more fuel . the c and d turbos are pretty restrictive and cause overfueling due to restricting the air and exhaust . this is how you can get more boost at lower rpms with the waste gate turbo without melting the engine with high egts.but the engine can still only take so much stress this is where the waste gate comes in
a waste gate is added to a turbo for these 3 reasons:
- to limit turbo speed at high engine rpms and prevent catastrophic turbo failure when matched to a specific engine (this is the primary reason)
- to reduce drive pressure to safe levels (preventing headgasket failure), again, depending on engine design constraints
- to allow a smaller turbo to be used on a larger engine or to decrease turbo response time - the smaller size allows for quicker spool-up, yet waste gate prevents turbo over-speed.
basically, turbos run off of fuel [read: exhaust] - add fuel and you decrease spool-up, increase turbo speed, drive pressure, and output (aka "boost"). the multi can't push enough fuel to stress the turbo. and if it does, other things fail long before the turbo does.
'porting' the turbo just improves the volumetric effeciency by reducing restrictions that cause higher pressure differentials. this will decrease the drive pressure which allows the turbo to operate a bit more effeciently. this efficiency increase will show by a [slight] increase of compressor output volume ("boost") and can allow more fuel to be run through the engine until drive pressure reach danger levels again.
think of it as work - the easier job it is to get flow through the exhaust, the easier it is for the turbo to push air. same principal as a free-flowing exhaust on a gas motor: easier out, easier in.
modern turbos have much better effeciency maps and have many more compressor and turbine wheel options to better match engine sizes and performance.
