wat size leaf spring bushings do m1010 take
itsunday25
pennsylvania
i need rear leaf bushings they have 3 to pick from idk wats one it takes one is 1-1/2 od and other is 1-3/4 od can you help i want to get parts befor tare down thanks
Cleptomaniac
Tecumseh ,OK
Really man?! It is one thing to criticize but how about constructive criticism? You could have at least offered some advice if you were going to post!!!
Itssunday25 I wish I could help but I don't know the answer!
Good luck
Warthog
227
OKC, OK
Looking at the TM 9-2320-289-34P Parts manual, Figure 150, the bushings for the rear springs are listed as #13(front) and #5(rear)
#13 - GM 350544
#5 - GM 468481
If you look at the diagram and the part numbers, the listing has a UOC numbers. This is the "Usable On Code". On page #4 of the parts manual lists what the "usable On Code" means. The M1010 is truck code 210.
Your parts house should be able to cross reference the GM part number.
NAPA is showing the following numbers.
GM 350544 - NCP 2741189 - $19.69 ea
GM 468481 - NCP 2741785 - $14.49 ea
You will need two of each.
It took me awhile to read your question. as we usually don't use TEXT Message words on this site.
Cucvnut
61
Carver, Oregon
Good luck
I guess you missed the thread about spelling and grammar in the conversation section.
Cleptomaniac
Tecumseh ,OK
No I didn't but I also know that you catch more flys with honey than vinegar! That being said I think that the same point could have been made with a little different approach!
I have been reprimanded on here for something I posted. But it was done in a way that didn't make me too mad. (well after I thought about it :) I'm still a little hot headed!
