TacticalDoc
- 26
- 18
- Otisville MI
I wen through all 20 something pages of the 5 ton mods forum and haven't see one on a water fording kit mad for the 5 ton. What would it to make a fording stack/snorkel?
do the axles have the valves like the M35A2? can you plug the bell housing like in the deuce?The air intake comes up behind the cab almost to the top of the cab on 939 series so I doubt a snorkle was used .
The fording kit has more to do with putting low air pressure in the axles and bellhousing to keep water out. They are limited to 50 or 60 iches of water fording and 24 inches or so without the kit.
the bell housing is an easy fix. an elbow with ball valve can be used. but if it requires more hoses and work on the motor I guess its not worth it. Whats the water fording depth on the 5tons now w/o fording kitThe bell housing has the same plug , never looked into what the axles have.
I did something similar with the deuce I owned. I ran tubing from the axles and gas tank up to the back of the cab. I also did bypassed the air pump to the air filter and put a snorkel on air intake.I vented the axles, transmission, transfer case, fuel tanks, and master cylinder (m809) up to the firewall.
No quite the true mil fording kit but it should help minimize my maintenance after I get into a little puddle!
I plan to run a mini regulator and another dash valve to pressurize the system to 3-5 psi.
We have NOS fording kits in stock for M54 series 5 ton, I am sure they can be modified to your applicationI mean with out a fording kit on the truck as it is can water ford into water reaching the cab and still run. But later will need the fluids replaced.The theory is that major components have a little positive air pressure in them so water won't get in. Personally i would do some testing before i decided to take a 25 year old truck into 6 feet of water. It was intended for crossing streams and small waterways. You dont want to leave the fording kit engaged for too long it can damage seals over time and cause other issues.
I don't plan on going through water but I would like to know the trucks limits in case I do. I read those threads and when I had my deuce it was easy enough to make a fording kit. But, on the 5 ton I'm not sure. It doesn't make sense to put the air intake above the cab which is standard on the M923 if it cant water ford to that level. I suspect that it can ford water well into the cab. The only issue would be after fording you would need to change the seals and fluids in the axle.I would give that a maybe. I started a thread a while back on fording. I dont know how to link it to here sorry. Different members gave their opinions and experiences. I believe the air filter area is a weak spot there is an o-ring seal if that is not properly seated you could suck in water. But I believe this could be the case with a fording kit also. I have to look at my truck and see if it has a better seal than normal. I believe with super single tires 3 feet should be ok (if your air filter is properly sealed) but you will have to do a PM after just to play it safe. Another member said he extended all the vent lines from the xfer case, trans and axles up to the top of the intake stack and he did ok in mud. I think if you want to zip thru a 3 foot flooded underpass for a few seconds you should be fine. An A2 truck may fare better in the axles the seals may be tighter since they have to hold the ctis air flow. The axle chuck vent may be the same though. How much water are you planning on going thru and for how long?
