Water in Front End ?
Loose Deuce
South MS.
I took both the front brush guards ,(or what ever thay are) off the differential for cleaning and inspecting. I guess the are to protect the rubber boots on the knuckle. When I took the two bottom bolts out, on one side a couple ounces of clear water came out. On the other side about a cup full of rusty brown gooey oil/grease came out. Is this from water getting bast the boots? Only water it gets is when I wash it, unless its been in there a long time. Gear lube in the chunk is clean. are these supposed to be greased or lubed often or does the differental oil takes care of that?
MVtrucker
Bridgeton, NJ
Boots are leaking. Running in rain will admit some water, I guess. Yes, lube goes in and it's covered elsewhere in SS, but I forget where.
