- 1,813
- 1,518
- 113
- Orlando, FL
No, not really. More often at the couple gas stations near home, but I get gas wherever.do you always get fuel at the same place? If so .. go someplace new for several tanks and see if same result.
I don't think it's that simple, which is why I asked. The fuel isn't coming from one place... Shell, Murphy Express, Love's, 7-11.You are buying crappy fuel. Its full of water. If you only buy at one place, you can see whats coming out in your water separator. If it looks like that, you need to try another place. Or accept the fact that you have crappy fuel.
If I were you, I would drain the separator EVERY time I shut the truck off. If you look in the operators TM, I am sure you will find this a DAILY function. By daily, they mean every time you shut down and leave the truck for the day. Gets cold there. Think about what happens to water when it freezes.
It does get cold here, which the heat / cold cycles could be "breathing" moisture into the tank, however, it's basically a desert here. It's usually 15% humidity, and rarely rains. That's why it's so weird.Thats crazy. I would add another filter separator from the tank to the first filter. Maybe rain water seeping in thru cracked fuel lines or something.
I was asking in case the winterizing additives are orange/red, or if the previous owner used red farm fuel it could cause this, etc. There are a bunch of logical reasons there could have been red stuff in there, so it's not safe to assume anything.The reason its red is rust. The tank is aluminum. Whats that tell you? Its not your tank. Do this. Take a gallon of your diesel, clean diesel, and pour a pint of water in it. Is it red? No. Not even close.
Everybody would be better off to never buy your fuel from gas stations they dont sale enough diesel there to rotate fresh fuel always go to your local truckstop preferably at a interstate exit ramp for high volume diesel sales . And for aditives its hard to beat howes fuel conditioner for year found use. years ago a diesel mech buddy of mine worked in a detroit engine shop they took like 5 or 6 fuel additives and a bunch of bowls and put each brand in its own bowl and put 1 piston liner o ring in each bowl before they went home one day and on their return the next morning found all the brands but fppf brand had made the orings swell and walk their selves completly out of the bowls by the next morning so no need to over use any of the stuff and with low sulfer diesel the norm now i put a quart of trannsmission fluid in the tank to help the fuel pump and to help burn carbon off injector tips.No, not really. More often at the couple gas stations near home, but I get gas wherever.
Interesting find. Where is that from? I'd like to read the rest.Could you be getting coolant pushed past the injector cups ?
You should start getting fuel once water is out water always lays heavier in diesel so it will always lay on bottom of fuel tank and filters . Try parking your truck where the front of your truck is up hill for few minutes then take your cap and strainer out of your fuel tank then take a flash light and shine down in the tank and if you have any trash left you will see it in the bottom of tank if you have a small pump and small hose vacume the water/trash out of tank then put a half bottle of howes fuel conditioner run it for a few days then replace your fuel filters and buy only truckstop fuel your not far from a loves fuel stop.Another question... when draining the water separator, does it stop draining automatically once the water is out? It seems like when I open the drain knob, some liquid comes out, but to totally drain it I have to unscrew further it until air can get past on the threads. How is it supposed to work?
Do the liquids flow out freely? When I open mine, some seems to drain out and then it stops because no air can get in. In order to drain the rest, I have to unscrew the knob a lot, until air can sneak in past the threads. Is that how it's designed to work?You should start getting fuel once water is out
