Water in fuel? Draining water separator?
Ronmar
8,407
Port angeles wa
Do the liquids flow out freely? When I open mine, some seems to drain out and then it stops because no air can get in. In order to drain the rest, I have to unscrew the knob a lot, until air can sneak in past the threads. Is that how it's designed to work?
No, you have to pump the water and fuel out with the primer. If you look at the stainless ring around the primer bulb, there are instructions printed there.
Opening the drain is also a way to check if your flapper bypass check valve above the filter(underside of filter boss) is sealing. If you open the drain and it sucks air back into the drain, that is caused by gravity pulling fuel back down the supply line to the tank thru that leaking flapper valve above the filter...
Awesomeness
1,523
Orlando, FL
Thanks. I did end up using the primer pump button, but didn't think that was right. That's what I get for doing it in the dark.
For those that want to see, here is a picture of the instructions on the pump button.
Ronmar
8,407
Port angeles wa
Yep, except ours don’t have the vent screw/bolt seen to the right of the primer ring and mentioned in the instructions...
Awesomeness
1,523
Orlando, FL
No, that's not how its supposed to work. I always drained mine just before turning off the truck. Then the system is under pressure.
How would the system be under pressure? On these engines the injectors are the fuel pumps... they draw fuel to the engine from the tank. The lines aren't pressurized.
coachgeo
3,553
North of Cincy OH
Sounds like another reason to put in a "Temporary Service Only" aux. Elec. fuel pump back by the tanks. Pushing fuel to the engine .....
. helps you limp by on your journey if you get an air leak...... till you are at a better place to service it.
. helps with air leak diagnosis.... pushing fuel OUT of the leak area (usually; not always) so you can find them easier,
. helps prime the system
. can help push water out of the water bowl of fuel filter too apparently ?
Awesomeness
1,523
Orlando, FL
That sounds like a complex solution to a simple and unlikely problem. I would carry a spare fuel line (all 3 are the same fittings, so make one to match the longest) before I would go installing pumps.
coachgeo
3,553
North of Cincy OH
except that will not help you find what line is leaking...... nor allow you to limp to a better install location; or limp along in fowl weather till better repair day.
Awesomeness
1,523
Orlando, FL
The redundancy argument is a never ending one. Yes, you could just carry two of everything... except that you can't. So, personally, I want multi function tools that I can use to solve a multitude of problems.
