RodUSMC1962
- 10
- 0
- Northwest, Indiana
That is not likely, and if it did your low air buzzer would go off as you lost air.
Air dryers exhaust every time the compressor kicks out. It doesn't matter if there is water in the system or not or if the dryer is clogged. At least that's the case with every air dryer I've been around.If the semi is releasing every minute or so it sounds like the air drier is clogged and needs to be serviced.
Along with the buzzer you should notice the gage drop also.I put the drain with pull wires so I don't have to climb under the truck. The only thing that bothers me about them is that I dont want somethning that I drive over tocatch on them then drain my tanks leaving me w/o brakes.
We route the cables so they are not hanging down.
If you are woried about them catching on something you can attach the cable to the truct with a small zip tie that that if it snags something the zip tie will break and the cable will just hang free.
Another issue i Have seen is the drains getting knocked off of the bottom of the tank. GL aims for thos things.
Yep, exactly what he saidWhat you're draining, specifically, is condensation. When the air compressor compresses the air, it heats up (air molecules are being pushed closer together, causing friction). The compressed air is stored in the tanks on your truck. When that compressed air is used (brakes, air tools, CTIS, whatever), it decompresses, causing the air to cool off (air molecules are allowed to move farther apart, resulting in less friction). When air cools, the humidity in the air condenses. What you're seeing is absolutely no different than the condensation on the outside of a glass of iced tea. It's just contained in the air tanks of your truck and needs to be drained occasionally (and by "occasionally", we mean daily).
phil
