Water in the oil
technoid
13
Middlebury center, PA
Hello, I just got my online auction generator delivered. Its an MEP 803a. I thought i got a nice deal but there was more water to oil in the crankcase. It might be a cracked head or blown gasket. Where can i get engine parts? Its a 1994. I think its an Onan engine.
csheath
196
FL
Don't jump to conclusions. Was the exhaust flap taped closed?
I would drain all fluids, fill the radiator with water, and pressurize it to see if any water makes it back into the sump.
See if the engine turns by hand. If it looks good from there refill with oil and try to start it.
NDT
5,840
Camp Wood/LC, TX
Almost always rain water. Pro tip: don’t buy the units with no exhaust flapper in the pics.
technoid
13
That is exactly what I think it is. No exhaust flapper. I ran 10w 30 mobile1 in it and drained twice with oil filters. Then dumped it again and put the 20w 40 with 3rd new filter. It runs like a clock. I am watching the antifreeze level now. Going to load the engine tomorrow after I pick up the correct plug for the transfer switch.
Light in the Dark
5,113
MA
The flapper is a two part assembly: the actual flapping lid, and a simple hinge. Do you have either part or are both gone?
Light in the Dark
5,113
MA
Yes I was going to send him that info separately, if thats all he needs. The hinge is tougher to come by... might need to go tractor flap if its gone.
Guyfang
22,098
Burgkunstadt, Germany
If you look at the TM, you will notice that the The hinge is coded XB. Items coded XB are normally not stocked, and can be only had by salvage or theft.
dependable
187
Tisbury, Massachusetts
A while back, there was a big lot of 802s that sat in GL yard for a while with a lot of snow on them(the sale pictures showed at least 6 inches). Perhaps some flappers were a little bent, or somehow water got in during freeze thaw cycles. Some members here bought them and they had water in motors even though flapper was present on their generators.
Most people added flappers to extension, I went with a downturn, like are stock on the 002s and 3s. Always noticed a rattle from the flappers on my tractor and chipper, wanted to avoid that with my new "Tactical Quiet" generator.
Guyfang
22,098
The down turn is for another reason, on the 002A and 003A. The elbows were added years after the set came out. The stock pipes pointed the very hot exhaust down directly onto the batteries. The extra heat caused the cells to dry out, and we were putting 4-5 sets of batteries in every year. Some young soldier figured it out and put in a suggestion.
dependable
187
How were the 002-003 exhausts before? On the ones I've seen the exhaust turns down, welded at muffler, sort of toward batteries at a 45 degree angle off muffler. Did they have them at 90 degrees?
Guyfang
22,098
The "stock" exhaust were welded to the exhaust manafold. The 45 degree elbows were added to direct the exchaust away from the battery trays. The parts TM give you a general idea of what was before and after. The adapters were supposed to direct the exchaust away at horz. Angle to the set.
