Water leaking through gunner's opening cover
Valence
565
Davis County, UT
When water is allowed to pool on the turret cover on my deuce, it will easily leak through, and I can tell much of the rust inside the cab is from many years of such leakage and resulting humid interior conditions afterward.
Is a bar like this to prop up the cover just something I need to fabricate, or can it be found somewhere?
AngusPodgorny
Arizona
I think the question asked by the OP is whether there was ever an "official" part developed to remedy the water pooling problem.
I would speculate that the military would probably not have had a need for this because if the truck were in use then the water would not have a chance to pool, and the personnel inside probably would have just cleared the water off manually. If there were a brace of some sort, it would undoubtedly interfere with the use of the gunner's station.
Unless you plan on stationing a gunner in your cab, I'd probably just fab something up to do the job.
Valence
565
Davis County, UT
Thanks, both of you.
Yes, I was wondering if there was an official part, but that explanation makes perfect sense.
But there's an idea, forget fabricating up a part, just start putting together your own little army. First opening: "Permanent deuce gunner."
Some folks likely started with an ornament, or a "better half", while others have taken the long term approach to "grow" their own!
Guess I better fabricate a bar...
Hahaha
