Water-methanol injection system on a 6.2L NA engine
Jozseph
New York
I know there is an long old thread in the "Deuce Modification and Hot-Rodding" forum, has anyone installed a water-methanol injection system in a 6.2L NA engine?
Joseph
Westech
CPL
6,104
212
cow farts, Wisconsin
In the 6.2 family of engines it would only be good for getting a few more MPG's. It would not be worth the effort in making more HP.
You would have to crank the injection pump to make more power. When cranked and on meth that engine will only put out 200 on the high side while melting down on the inside.
A good safe HP level for the 6.2 is 150 ish. The 6.2 is a fuel efficient engine with good low end torque for the time it was designed.
Truckyea
Elyria Ohio
I swapped in a 6.5td, and was thinking about doing the meth injection to help keep the EGT's down while getting max power in off-roading situations.
I like the snow performance once that is tunable with the pyrometer.
So you can tune it to only kick on via boost or egt
