brow7392
- 0
- 0
- Moscow Idaho
I need to install a new water pump in my M885. It's my understanding that the radiator and water pump are heavy duty (as if the truck had AC) The only pump i can purchase locally has the same number of impellers (
but they aren't as big overall. The parts store doesn't even have the heavy duty water pump that is the same size to order in. My question is do you think it would matter to have the 8 impeller pump on it even though the impeller blades are a bit smaller? I think it would be fine because it doesn't have AC, i would lose a little cooling ability but i'm not sure if the difference would be enough to worry about. Thanks for the input.
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
