Waters intrusion into passenger insulation?
911joeblow
68
Utah
Make sure it is not coolant. That is a common location for coolant to collect with a bad heater core.
Bulldogger
589
Quantico VA
Mine was the same on pickup too. A few jabs w a screwdriver down low and it's fine since.
Bulldogger
Action
1,551
East Tennessee
In the black rubber door seal running around the outer edge of the door......mine begins on the edge right below the door handle is ......
OK, so then you would take the door off and lean it over so the handle is towards the ground, thus allowing the water to run out. If you flip it over, the water could just move to the top half.
