Alright I’ve got an m1009 that had a botched 12v swap done, so I have most of the components to swap back to 24v if I choose. Once I get a new cab harness....... anyways, eventually I’m going to add a sound system, and want to know what’s my best route for the most available wattage. Basically i’ll either go with the Roscommon split 12 setup, or stock 24v setup. I’m thinking I’ll be better with the split system after reading around on here, but I’m just curious how the 24 volt system would handle it, and what sort of wattage I could push with the stock setup, since it drops back to 12 volt. Well technically only uses one battery for most of the truck. Either way that would change the wattage. It would just be nice to have the 24 volt starter. Also if anyone happens to know, I’d like to know what sort of power is required to run the truck, like how many amps it needs to run, drive, and have lights, so I can decide if I want the head unit and components tied into the charging and starting system, and have the sub tied into the accessory system, or all of them tied into the accessory system, and eventual add ons like 360 cameras or a winch, in the starting and charging system if I go with the split 12 volt option. Sorry for the long post, I’m bad about not shutting up lol.
