Ways to make a deuce quieter and warmer in the cab.
ShaggyTheGreat
california
So, i am buying a deuce in the near future, going to be an m35a2. Im sure more people then me want to make it quieter and warmer in them, i have been in the passenger seat and my god it loud and cold as soon as the temp gets below 40. So, ideas/products to help reduce these 2 prominent downsides to owning a deuce? Im not a fan of rolling down the motorway with earplugs/earmuffs in. A you look, odd. B i feel like i am driving blind almost, to me hearing what little you can of the outside is important. :D
shenkmen
12
Lancaster, PA
I added an aftermarket heater, a Donaldson muffler and Sirius satellite radio piped into an aviation intercom system with "push to talk" buttons on the head sets.
1,827
The most effective way to quiet a deuce is right at the audible input area. You can reduce it quite a bit but unlikely to get it comfortable without re-routing the exhaust out the back and major insulation. It's never going to be comfy, that was the absolutely the last consideration of the design.
Warthog
245
OKC, OK
That is why a lot of truck have the "Hearing protection must be worn" sticker on the dash. They are not a new sound proof truck. These trucks where designed to move troops, not to run the the grocery store to get some milk.
What did you expect?
A member has been selling an insulation kit in the classifieds. You might check there.
MWMULES
352
DESOTO, KANSAS
Hardtop, heater, winter bra, caulk all the holes, boots for the levers, muffler, new seats, civi wipers with arms and insulation. Oh and
[h=1]Carhartt coveralls[/h]
wreckerman893
Possum Connoisseur
15,647
2,140
You can't gold plate a turd (well you can but then you just have an expensive turd).
Deuces were built for function not comfort. I put a lot of miles on a deuce in Germany back in the 70's. Warm in the summer, cold in the winter. I prefer the heater that mounts on the firewall verses the on that is inside the engine compartment. It seems to work a lot better as far as keeping condensation off the windows.
I added a muffler to my M275 but the effect was minimal.
As stated above there are ways to improve creature comfort slightly but it is what it is.
RAYZER
59
sanford/florida
The high noise levels, extream cab temperatures and a steering wheel that you have to wrestle are all part of the Deuce's charm!
EMD567
Driver for the Ga Mafia
Aiken SC
I have found that a blond is a good cure for both the noise and the cold. She puts her hands over your ears for the noise, and sits nice and close to you for the warmth.
gungearz
northwestern indiana
Actually boys... I did find a cure to take the bark out of the exhaust. let me explain, the stack is placed just over the height of the cab and my passengers seemed to always get headaches from leaking exhaust fumes in the cab... so I decided to add the magnaflow muffler raising the stack an additional 18"... which places the fumes and noise further out of the way... for all the banging around on the floor, I cut 3/8" rubber roofers mats to fit... without emptying the bank account, I see that as the cheapest way to do it.... but in the end, it will always sound like a deuce...
P.S... the muffler I have is hidden under the factory heat shield, so you can't even tell it's there...
1,827
Just for ships and giggles, one day while you are cruising along on an unpopulated road, pop the truck in neutral and shut down the multifuel. I think you will be surprised and just how loud the truck is even without the engine running. What do troop seats and Harleys have in common?? They are both predominatly noise generators. The best mufflers you can use are the ones that cover the audible input holes of the brain housing group.
welldigger
17
Benton LA
I dunno. The muffler I added made the exhaust the least obnoxious noise in the cab. I didn't change the stack height and after it gets painted you won't even notice it there. I can go up to about 45 before needing my ear muffs. After that the drivetrain noise gets too loud for my comfort. My next step is a hard top and dynamat.
cattlerepairman
3,520
NORTH (Canada)
Parking with the engine off does wonders for the decibel level in the cab. If you park in a heated garage, it is also nice and toasty in the cab. Sorry. Other than that, I got nothing.
KaiserM109
SE Aurora, CO
My M109 has the exhaust routed under the cab and out between the back duels. There's a muffler right under the passenger the size of a small kitchen trash can. The exhaust noise isn't bad.
I once insulated the floarboards of a '70 Ford F100 and was amazed at the reduction in the noise. One problem, though, it holds water and causes rust.
Maybe there's some kind of spray on foam that you could put against the sheetmetal and cover with removable floor mats so you could just hose it out.
peashooter
209
Hanover, minnesota
I bought some of the shift boots from Jatonka. It really helped keep the engine heat and smell out in the summer, (and probably keeps the heat in the cab in the winter). The canvas boots were high quality, but the metal retainers were not, so I ended up making my own. I'd say a muffler and the shift lever boots would be the 2 most helpful things in my opinion
http://www.jatonkam35s.com/m35shiftboots.htm
Good muffler comparison here: http://www.steelsoldiers.com/showth...ffler-option&p=1485981&viewfull=1#post1485981
