WC-51 Restoration or Bust!!
Tinwoodsman
76
Comfort, Texas
On Friday I used the needle scaler to remove the heavy paint layers on the front fenders prior to sandblasting. A picture is attached. This weekend's project was to sandblast and epoxy primer the front fenders, grill, front light guards and the outer windshield frame. Also painted the tranny tunnel and the inner windshield frame which was already prepped and I will take it to the glass shop next week. I still have some serious body work to do on the lower portion of the outer windshield frame and the front of the passenger side fender. Now I am on a 24 hour Crown and beer break. :-D
Needle-Scaler-Results.jpgD.S.-Front-Fender.jpgP.S.-Front-Fender.jpgGrill,-Light-Guard-and-Wind.jpgTranny-Tunnel-and-Inner-Fen.jpg
zout
154
Columbus Georgia
You have been on a break last two years fella - get the lead out that is all simple stuff to get done before ya go beddy bye. Why is there always chit hanging in the air around your garage - does it smell ??
Tinwoodsman
76
Comfort, Texas
I can't wait until the Rally so I can give you a big hug!!
:tank:
Tinwoodsman
76
Comfort, Texas
Got the reproduction inner windshield primed, painted and glass inserted. Finished the windshield frame and installed the bottom weather strip and turn tabs for the cab cover. Painted and installed the two floor pans but still need to install the brake and clutch pedal draft pads. Finally, painted the oil can bracket and installed on the firewall.
Body work has been completed on the front fenders and inner splash walls and hope to paint tomorrow.
saddamsnightmare
80
Abilene, Texas
September 26th, 2013.
Tinwoodsman:
The oil can holder is pretty cool, kinda like the ones used on some Model "T" Fords...What keeps the can from bouncing out on rough roads or terrain? And is the OD WWII No.7 or something different? Also, what did you use for the loom covering on your wiring? I seem to remember one can still get the cambric loom covering tubes, but it has been awhile since I looked! Good job so far, keep it up soldier, the end is in sight!:naner:
Tinwoodsman
76
Comfort, Texas
Tinwoodsman:
The holding bracket for the oil can has a spring loaded claw fitting that grips the can. The OD is late WWII #319. I did my own harness and the covering is made up of sections of various size heat shrink tubing. Thanks for viewing.
zout
154
Columbus Georgia
Oh Where Oh Where can he be
can Tinwoodsman MV's work be gone
oh where oh where can it be
He's got a trailer
and a WC
we've all been awaiting
for pictures to see
He stall's and he waits
as he mecticously works
and has tiem for his other qwerks
oh where oh where can he be
His thread almost went out of sight
time to get back to work
and give us a view
before I gotta head to San Antonio
and give him some hellaa balu
Tinwoodsman
76
Comfort, Texas
I would have had the WC done by now but I just cannot deal with losing my reputation of "the slacker". Went to see the guy who was supposed to repair my right front fender. He fell and fractured his scull and was in Intensive Care for over a week. He is back on the job part time as of yesterday and hopes to get me my fender by next week. If not I am going to take it to the guy who did some bodywork for me on my 1950 Ford F1.
Did get the clutch and brake pedal draft pads and brackets installed. Repaired some cracks in the steering wheel and clean, bead blasted and painted my air cleaner. Sorry Commander! I will press on.
zout
154
Columbus Georgia
whoooo baby - I have pic withdrawl relief.
I still work when I hit my noggin ??? is that fender fella a slacker as well ??
Looking at that floor board should be a scratch & sniff picture it looks so perfect
Tinwoodsman
76
Comfort, Texas
Gave in to serious pressure from a certain party who shall remain nameless. Got the steering wheel and horn button installed today. Then I installed the refurbished air cleaner followed by the wipers and vacuum plumbing along with the rear view mirror. Finally, I installed the seats. Hopefully I will get my repaired fender back within a couple days and I can finish off the front.
zout
154
Columbus Georgia
TWM - I have resorted to make your invoice for harrassment to zero balance - service is free as your producing results now. I can always send you the invoice sealed with a pink zip tie if needed.
