WD40 Cure???
1,814
I doubt that anything will do that. Once they get crusty, just wear em out quick and scrap em.
Elwenil
40
Covington, VA
Rubber decays just like everything else. There's not much you can do about it once they are dry rotted. You can make them look better with a little shine like some many of the monkeys on Ebay do, but there's really no help for it. If I remember right, WD-40 will eat tires up so that would only make it worse.
Jones
Sacramento, California
WD40 isn't all it's cracked up to be. It's a moisture grabber so it'll actually form a thin water layer and rust the parts it's supposed to be protecting. On metal, Kroil is what we've gone to with far better results. For long term storage of machined surfaces, a coating of any of the spray-on, turns-to-a-waxy-coating products are good to use.
We don't coat our tires so don't have any recommendations other than we're instructed NOT to use Armorall.
devilman96
17
Boca Raton, FL
Liquid silicone is actually the thing to use for a protecting tires, It will not fix the cracks but it will protect the tires and add moisture to the rubber... IMHO...WD40 is crap for any application.
Katch1
neillsville wi
wd-40 is more of a solvent than a lubricant, one other thing to remember about wd-40 is that it attacks loctite thread lockers and sealers.
