mistaken1
- 6
- 0
- Kansas City, KS
The only option I see is to physically trace wires.
There is only one place to get 24V from and that is the positive post of the back battery.
Perhaps a 24V wire and and a 12V have rubbed together until they made conductor to conductor contact and you are back feeding 24V into the rest of the 12V system.
So, what happens if you remove the jumper wire from between the batteries and put the back battery positive wire onto the front battery positive post?
This will let you feed 12V into the 24V part of the wiring, the truck will not start but this test would allow you to user your meter to see if somehow 24V (now 12V in this test) is back-feeding into the normal 12V system.
If there is indeed a back-feed situation this will allow you to take your time and use your meter tracking it down without damaging components during this troubleshooting phase by subjecting them to 12V instead of 24V.
If you make this temporary connection it should remove the feed to the diamond shaped 12V bus on the firewall meaning that if there is no back-feed the only place you should find 12V is on the 24V part of the electrical system.
