Weel leaking need seal
harry
Robbinsdale/MN
I have a weel on M35a3 ( two piece weel ) has a slow air leak. Its not the CTIS . looks like leaking between weel halfs , sprayed some soap were filler pipe goies thur weel and was bubbling in around gap . Is their a big o ring that goies between the weel halfs and dose any one know were I can get one
Thanks for the help Harry
harry
Robbinsdale/MN
HI DR Greg
It is in Minnesota Next to Minneapolis , spend time in Dandury Wi ,
I ordered a seal from Erics parts when I take weel or wheel apart I will measure and should be able to order from MC Master car they have everey thing if you know size
Harry
cbvet
20
Northwest (Knox) Indiana
Harry,
My M813A1 had a slow leak which was getting worse. I have the 10-bolt 900 series wheels with 1400-20s.
Found leak to be at the hole where the Schrader valve comes through.
Got a seal from Memphis.
Last weekend I broke it down. Those 10 nuts were tight ALL THE WAY. Found out there are beadlocks in there! O ring looked pretty good but there was some light rust on the wheel contact surfaces.
Wire-brushed & steel-wooled everything clean. Washed tire & wheel so there would be no sand to get in my new O ring.
In a pinch I think I could have cleaned & used the old O ring, but I put the new in.
Holding air just fine.
I never could have done it without my old forklift & a 3/4 inch impact.
Eric
CBVET
