Wehring - Continental AC70 chevron tires and locker
Suprman
707
Stratford/Connecticut
C7 trucks have data bus. You can access the Ctis controller via the trucks main diag port with a laptop, Dana software and a port interface.
dronsen
12
Bozeman, MT
Justin-
Good to hear from you - and nice job! What size AC70's did you use? Any reason they wouldn't fit onto 20x10 steel wheel?
wehring
32
Angleton, TX
425/75R20
factory FMTV wheels are non-MPT bead wheels. These tires have an MPT bead. A friend runs a set on non-MPT MRAP wheels and says they work fine but I have not tried it to have an opinion.
Justin
dronsen
12
Bozeman, MT
Huh-
I never heard of MPT wheels or tires before now...just did a bunch of Google-machining and understand better now, though still haven't seen a good photo comparison for a complete understanding. What were the 20x11 MPT wheels off of that fit an LMTV?
Thanks!
ramdough
1,731
Austin, Texas
Has fast gear conversion.
i can reprogram the CTIS. Can change over speed values and psi values. Can also trouble shoot and check codes. $125 hr
Is that only for C7 trucks? Can you read engine codes for earlier trucks as well?
Suprman
707
I can read codes on 3126 A1 but it dosnt have the data bus like the C7 A1 trucks. First gen trucks are mechanical engine. There is an Allison diagnostic plug on all of the trucks but it takes specific Allison compatible diagnostic hardware to read. I spoke with a Dana engineer at one time he said he thought the 3126 A1 trucks had the ctis controller connected to the main engine data port and he thought ctis programming could be done on these trucks but I have not had a chance to try. I have everything to do it if it does work.
Keith Knight
2,153
Wauchula, FL
I seen a set at a local tire store, they were asking $100 each. All the measurements are correct and I like how the CTIS is mounted. To make it work from what I can tell would require a cross hole drilled in the large wheel stud that supplies air to the CTIS an o ring behind the wheel on that stud a threaded plug on the end of that stud and maybe some thread sealant on the lug nut.
Have you figured it out?
