chucky,Is there a chart to tell us what number to use on our particular trucks or as per how much weight
We never changed the weight tags according to load. Heck, we never even LOOKED at the tags.chucky,
As mentioned above by SCSG-G4 - The "DOT Man" does not play. You don't want to get caught over the weighted tag limit for your truck. They will park you on the side of the road for weight and for faulty equipment until you resolve the problem - and tossing weight off on the side of the highway - won't cut it with them. Even a "non-commercial" vehicle is regulated for weight and safety equipment AND are their concern on the public roadways.
It would be cool to know if the military drivers actually changed their Bridge Plates according to the load they were carrying. OR maybe they were set to the heaviest load rating - and stayed that way. My 1088 has one and the numbers on it don't look like they have ever been touched. No scrape/slide marks at all...
I probably didnt state the question properly. I was wondering if there was a chart that listed all the lm/fm trucks by there weight and what number on the bridge plate number should be on that specific truck . I want to display the correct number on the plate on my truck/ trying to make it look like current issue truck and i figured the m-1087 would be fairly close to a 1083 with a all steel camper on it. Ive finally painted my project solid OD 383 green so now i want to put all the stensil work and safety plates ect .Weight of the trucks is in the -10 tm
Yes that what im shooting for like whats the plate on a 1087 have on it ? Its 3000 lbs more than mine but close enoughI could be mistaken, but I think the OP was asking for guidance on the bridge plate number to be used with his/her truck. I think they were asking if there is a resource out there that specifies the numbers to be used for particular model trucks.
Are you trying to come up with a Gross Vehicle Weight Rating for registration purposes? If so, and your state has 'weighted plates' (the greater the GVWR, the higher the cost of the plate), you need to think carefully. First what is the empty weight of the vehicle, second what is the maximum weight of cargo that you ever plan on carrying, third what is the maximum amount of cargo the military says could be carried on paved roads by that vehicle. If the second number is substantially lower than the third number, you may save a ton of money in registration and tag fees by using the lower number (1 + 2, rather than 1+ 3). However if you go that route and cheat, going over the declared max weight and get caught, your ticket could negate a decade's worth of tag fees. For my deuces, I max out at 4,000 pounds of cargo as #2 and the closest I've come is carrying a deuce engine in a can, which is 3,100 pounds. #3 for a cargo deuce is 10,000 pounds, so I'm only carrying 40 percent of the max value on my registration. In SC, the extra weight is about $20 a thousand pounds for the annual license tag, other states may be more.
No i was trying to find correct plate number to put on my truck as per its weight
Thank you for the info and Thank you for your service .Yes, there is a document that lists every vehicle and trailer. If yours were an OLD vehicle, I would tell you to open up FM 5-36, Route Reconnaissance and Classification. I have no idea what the current document is, as I have been out 28 years. But there is a document. I THINK the FM 5-170 has the list, but its just been too long.
ok i didnt know you could google the tm stuff thats great my 1083 with my steel box and interior im fairly sure im 25 to 26.ooo lbsThere are two models of M1083. With and Without winch. What model do you have. I can look in the -10 TM, and the gross weight should be listed there. Or you could just google the TM and look also. Its on page (PDF reader) #91. Wont let me copy it and paste.
Its a start and a lot more than ive found ! Thanks I figure im around 26,000 or closeI believe I read somewhere...and I am sure someone will either confirm this or shoot me down ...that the bridge plate number is something like half of the GVW of the truck (if a trailer is being towed, the bridge plate would show the C for COMBINED and that weight would be included). So, if the GVW of the truck is 36,000 pounds, the bridge plate number would be 18. If I recall correctly, this is not exact, but it is approximately accurate. Again, that is my recollection from previous threads on this. I might be remembering it incorrectly.
Bruce - I get what you mean, but I think you actually were referring to 1/2000th.... ie., it's direct "Tons" and not pounds.I believe I read somewhere ...that the bridge plate number is something like half of the GVW of the truck
