Weight badge numbers chart???
chucky
19,294
TN .
RR&C
Once your truck is outfitted for its normal operation just scale it on a truck scale to get your estimated tons for your bridge plate display
Follow the cmv Bridge formula regarding drive and steer axle weights.
Thanks for the info.
chucky
19,294
TN .
When you hit 26,000 you get into CDL territory. It is in your best interest to keep the gross weight UNDER 26,000 pounds for licensing purposes! Unless you ALREADY have a CDL and plan on keeping it! Even then it can get expensive quickly.
Thanks I have a cdl and its an age old discussion on here about the weight not being a factor in a motorhome /camper as long as not in the commision of enterprise ie 50 to 60 thousand lb marathon /prevost motorhomes and the owner / driver only having a OPERATOR DL and regular civilian tags. Not to say you wont run across an LE that hasnt dug into the books on the subject .
