Weight change in doing a axle swap?
scratch
Gloucester Va.
I have been thinking about an axle swap on my 68' m101a1 for a while now. If I was do do the axle swap and remove the front landing leg, remove the pindle hook and change it to a ball and hitch, does any one know how much lighter it would be? I would like to know what the axle weights, what the tires and wheels weight. and what the front landing leg and pendle hook set up weighs. Thanks
rtk
427
Lockport N.Y.
I would say 200 to 300 LBS. more or less , for the axle weight , tires would save a lot of weight . What about the brakes , are you putting brakes back on ? if not then , add about another 150 LBS. or so to the total . As for the hitch depends how much metal you add to put a hitch and landing leg back on . I would guesstimate about 400-500 LBS for all total .
scratch
Gloucester Va.
this is before adding new axle and everthing right?
rtk
427
Lockport N.Y.
YA , as I said just a guess , but the wheels ,brakes , hitch and landing lag are HEAVY . BTW , I would post the wheels ,backing plates and drums on the G741 site , The drums and wheels are the same as a M37 . bob k
