- 3,331
- 2,220
- 113
- Pemberton, N.J.
Yup, when it knocks your camera down that is a Detroit locker slip/lock.
A "posi" is a limited slip. A locker is a locker.Likely it will push straight unless enough speed is had to transfer weight from the inside, to the ouside. The longer the wheelbase with heavier front axle, the less push will be occur.
One of the best analogies for a welded diff would be riding an old honda atc three wheeler. It had a straight axle, no differential action and was very short wb. If you just sat straight up in the seat and turned the front wheel, it would just push straight. You had to transfer from the inside wheel so it could loose traction in order to get it to turn. Later londer wheel base atvs came about and had better turning manners.
The detroit lockers to those new to them, can be very nerve racking at first. They have very bad street manners and are noisy and unpredictable in their action. Once a turn is made and the outside ratchet disengages from the carrier part, it does not always just click back in when going straight. It can stay disengaged for a bit and engage when accelerating. This is when, until you have some time with them, it can scare you as the engagement will be vary abrupt, with a loud clank and the vehicle, depending on the weight of it, will shift slightly to the opposing side of that that was disengaged.
Like this rig, you can hear the noise I mention. I have one in my 3/4 ton 2wd pu and one in my Steiger tractor. The pickup scares people on the sidewalk when it clanks into posi. The tractor works awesome on the soil, and sucks bad down the road and in the farm yard.
Agreed fully.A "posi" is a limited slip. A locker is a locker.
If the front axle was disengaged, and a desplined drive flange was installed on one side, I do not see how this would happen.I would think that a welded diff in the front of a deuce, when engaged off road would be undrivable. It would not steer. This is not a 2,000 lb. Jeep you are talking about here. And I already know what your next question will be, "well what if I only engage one side?" That would be fine until you hit hard pack, or better yet you are spinning the tires to get out and that one tire grabs. Instant turn! Do NOT have your thumbs on the inside of the wheel!!! If you really insist on welded diffs then put them in the rear and buy lots of tires.
As long as the front axle is disengaged, you should be able to drive the vehicle equipped this way. But when you engaged the front, even off road on slippery surfaces, You will positively drive the one splined wheel. Because the tire is not directly over the steering pivot line, any traction on the tire will tend to pull that tire forward and do so against the drivers attempts at keeping it straight. And, when hitting the brakes, it will jerk the wheel out of your hands to the opposite side.If the front axle was disengaged, and a desplined drive flange was installed on one side, I do not see how this would happen.
BUT, ive been wrong before...
