- 1,869
- 1,265
- 113
- Ostrander, Ohio
Well I tried getting the hinge pins out of the tailgate, tried several methods. I just snapped the bolt on piece of my farm jack trying to loosen them. Screw it, the sawsall is next.
The project is to try and straighten out the damage to the tailgate and bed. I used an 8 ton bottle jack trying to push out the metal in the floor, lifted one side of the truck off the ground with no results. So the new plan is to remove the tailgate, and cut out the end panel of the bed and straighten it. Then fixing the floor should be easier. I'll have to practice some gas welding before I try to put it back together. The tailgate will be the hardest to straighten, I may have to cut out the worst of it and weld in a new piece. I've got a lot to do, but since it's still warm, I want to get on this so I can get a couple of good primer coats on it before it gets to cold and wet.
