What 6.2 engine is this???
andytk5
florida
This went for auction in the 650.00 range when another 6.2 was 170.00, plus I have never seen on listed as a 6.2 with what seems to be a crossover pipe in the backside with a turbine housing and turbo with inlet tube running in between the intake banks in the valley of the motor???
andytk5
florida
Thats the EPA version of the 6.2. It routes the exhaust into the intake.
Lol!
Thanks guys, i guess from hmmv's? seems like these would be great upgrades in the m1008-9's after the 6.2 has had it, though I am not sure what the firewall clearance would be in keeping that setup, prob have to go to to the pass side.
Chief_919
100
Western NC
Lol!
You can't convert a center mount turbo to a side mount- not unless you also change heads anyway.
jj
Kutztown,PA
Same turbo set-up as on the civilian full size van. Not TOO bad to work on after the doghouse inside comes off. It would not fit a Blazer or Pickup by probably several inches at the firewall.
ken
25
Houston Texas
That my friends is a marine 6.5. I have seen a few of those mounted in work boats.
